B brianc218 New member Joined Jul 9, 2007 Messages 1 Points 1 Mar 11, 2008 #1 I have a question, I had the head rebuilt on my 1977 Spider, it has been installed but now I find out the number three cylinder hole is stripped. Is there a way to fix this without removing the head again?
jug blessed are the apostates Parked in the garage Joined Nov 28, 2005 Messages 27,935 Points 3,853 Location Durham Mar 12, 2008 #2 i guess you mean the cylinder liner is damaged, i would replace it and also replace the piston ring. you could drop the sump, then the crank, and then the piston.
