... when previous owner baked engine, he also grinded block & head surfaces...
Honestly I doubt he had those re-planed, MAYBE the head (since it was removed) but most likely NOT the block (since it needs engine removal) ...
Renewing (seriously) an engine is not a DIY job: a LOT of parts will need to be replaced/rectified and some engine will even be "not renewable" because of excessive wear and/or spare parts un-avaibility.
The cheap engine revamp is usually to get the head off, plane it on a "marble" (not sure if that's correct) and get the valves "grinded" to their seats. Valve tail seals are usually provided with the head seals kit so having them renewed could also solve oil consumption/blue smoke issue.
Next step would be to renew the "down" engine: crankshaft and rods cushions, together with a potential trunions rectification.
And finally comes the piston/cylinder stuff:
- cheap(ish): expansing rings (Goëtz or other brands)
- expensive (but might be necessary): cylindre re-bore and new pistons & rings.
Finally, if I had a nice running car, I wouldn't bother about a "ticking" noise that can only be heard by the surrounding peoples.
OR I would completely dismantle it to peace my mind ...
Of course those last options can't be easily done on a parking lot, without tools, little knowledge and winter coming
BRs, Bernie
If someone here helped You fix -or better, understand- your issue, hit the thanks icon @ bottom right corner, it's free and makes us feel helpy ;-)
