Technical  Engine fans not working
Butler85
Does anyone know why the engine fans won't work on a Doblo JTD. The problem started a while ago, since then the rpm sensor has been changed and the engine due to other problems. With the engine change the wiring loom in the engine bay was changed as well. Checked the fuses and the electrics to it and they are fine. Using esu scan I can switch the fans on at both speeds and no errors occur. But the engine temp is rising and no fans will come on. Any ideas pleases.
De
