999 cc Fire engine with Webber carb , Distributor with factory electronic ignition .
Engine is running fine for 5- 15 mins then cutting out dead , no sparks to plugs.
wait a bit and will restart and repeat the process
The Electronic ignition module on the distributor seems to be getting very hot to touch . [ but it is bolted to the dizzy which is also very hot from the normal engine temp. - heat transfer]
I think the module might be breaking down ?
or Could it be a faulty coil ?
Does anyone have any ideas
If anyone has a spare coil and /or ignition module that they know are good , I would gladly pay some beer tokens to borrow or buy them so i can do a direct replacement test for my components .
Carl
Carl
