jjacob
I have not been on the forum for awhile due to starting a new business. My 1969 500L has languished in the mean time. I decided that I wanted a 650 engine and transmission, but of course in the USA these are almost impossible to find or people think they are made of unobtanium.
I just recently purchased not one but two 650cc engines as well as a 126 transmission on eBay Germany. I have a friend in Germany who is going to crate everything up and send them to me.
Thought I would share my plans and get some comments and advice.
I have decided to stay with the stock 650cc displacement. I cant justify spending a lot of money for another 45cc's which will likely only yield a few more horsepower all by itself. Carburetion, head work, compression increase, and a more sporting camshaft seem to be the ticket to most horsepower increases with these engines. The cost difference between 650cc cylinders and pistons vs. 695cc is huge. Parts are way more expensive plus the added cost of machining.
So here is the plan:
Thanking you all in advance.
John
- Rebuild engine. Determine condition of cylinders and pistons. May only put new rings in with a hone if everything else looks good.
- 35mm intake valve. Stock exhaust valve.
- Hardened valve seats and some mild port work.
- Sport camshaft
- Aluminum 3.5L sump
- Clutch disc with spring center rather than solid center disc.
- Oil filter and cooler set up.
- Retain existing Weber 28IMB carb with a rebuild.
- Tubeless wheels with 135/80R12 tubeless tires.
- Pertronix electronic ignition (currently on my car)
- How much would I skim the stock head to get something around a 8.8 - 9.0/1 compression ratio?
- I am thinking of getting a welded and balanced steel fan. I have heard the stock fan is prone to letting go and the aluminum ones are inefficient.
- Camshaft - thinking a 30/70-70/30 or 35/75-75/35. I want torque. Power over 4500rpm does not interest me. I want fairly smooth idle and pulling power. Cruise at 60mph (100kph)
- Is it worth the money to get a bis crankshaft? Car will be driven not only around town but on longer trips at constant 50 - 60 mph for hours. Is the stock crank up to that task?
- Exhaust type: I am wanting better flow but I do not want to suffer a loud exhaust or one that drones. I am thinking of the types that either have a collector "Y" into the center or into the end. To me this is better balanced. Into the end seems better flow wise. Are they all loud other than a stock muffler?
- Will the starter motor from my 110F engine fit the 126 engine and transmission?
- Thinking I will keep the flywheel stock weight. Smoother idle and will dampen the inherent unbalanced nature of a two cylinder engine.
John
