ceefox
Hi guys, just spent out tidy sum having a new cam belt set, oil, fuel, air filter and replaced a top oil breather pipe in turbo pipes which had split. Garage disconnected battery to do works and when reconnected up pops engine management warning light - solid display!!
Plugged into the garages diagnostic kit ( they are a local independent Fiat specialist by the way) and 2 faults appeared: one said low air con and the other hi speed fan relay, We have gassed up the air con and we put a new relay in for hi speed fan, but after resetting the codes via diag' kit, they immediately reappear on start up. Other than the codes the car was runnig fine and fan was cutting in ok.
On Friday I took it on a good run in and around the city - warm day around 20C loads of sitting in traffic, stopping and starting all day long no problem, temperature rock solid at mid point of display, then we got to a roundabout and as I pulled away got a horrible clicking knocking noise from under bonnet and all of a sudden engine stopped and no oil pressure message came up managed to coast to a lay-by and engine would not turn over, recovered it to the garage and up on the ramp the engine turns over roughly 270 degrees forwards and backwards and then comes to a stop...anyone got some ideas???
In addition to the above listed works I have also replaced turbo 3 months ago, a new windscreen and 4 new tyres plus wishbones, drop ends, anti roll bar bushes and tie bar ends last week, so far have now spent c£1400.00 in last 3 months and need to be sure whether I spend anymore sorting it or just offer it up as a non runner with lots and lots of new parts
Really need some good advice here peeps
much thanks Ceefox
much thanks Ceefox
