Technical Engine #263A2000
sarge2771
Hull
Hi all , just joined and after some information if you can help.
I’ve recently purchased a Vauxhall combo 1.3cdti 2016 knackered engine seized due to no oil.
My question is my log book says engine number :263A2000 and looking at purchasing a doblo engine :263A2.000 2013 am I right in assuming this is same engine and should fit .
Any help appreciated thanks Gary
I have a 2014 Vauxhall Combo D which I believe apart from the badges is basically the Fiat Doblo of that era including the same headlights that slope back over the top of bonnet/wing area unlike the older versions. I have just bought a s/h gearbox for it and they are advertised as Doblo/Vauxhall combo. The older version was different and pre DPF etc.
Thanks for the information
Is there anywhere that has torque settings for drive shaft nut
Tia
Tia
Strangely enough , yes!
I am just finishing off replacing the gearbox in my 2014 Vauxhall Combo 1.3cdti.
I am having a job getting the new drive shaft hub nuts with the revolving washer as both of mine had the locking part well knackered.
According to my 2012 Auto Data Manual 120Nm, slacken off, 20Nm then finally 90 degrees.
On section 122 front hubs it says special notes 49 which is as follows. Sorry for shaky photos.
Incidentally are your hub nuts 36mm like mine and are you finding it a very tight fit for a decent socket to squeeze past the lip of the hub. In the past I ground the edge of my 3/4 drive socket, but recently I have been offered the use of a thin wall socket to do the job.
Hi , thanks for reply yes 36mm yes tight to get in I’ve grinded down impact to fit
