Technical Enable Cruise Control Ducato MES
ian963741
Worcestershire
Has anyone got any tips for enabling cruise control on my 2020 Ducato please!
This is what I've done so far:
  1. Added the Cruise control stalk taken off a Ducato 2017 switch set onto my van and connected it up to the spare wire already under the steering wheel
  2. Enabled Cruise Control in MES
  3. Completed a Proxi alignment successfully
This is what I'm seeing:
  • With the Cruise stalk connected, the little green cruise light appears on the dash and 'Cruise Control enabled' shows up
  • It doesn't matter which option I choose on the stick (Cruise, limit or nothing) - the green icon remains
  • If I disconnected the stalk, the dash shows 'Cruise Control disabled' and the green light goes out.
  • I can't seemingly set a cruise speed, adjust up/down etc
Could this stalk be broken or incompatible or have I just misunderstood how it works!
Any tips - thanks!!
Thanks!
Year
2019
UPDATE: Turns out I needed to enable the speed limiter as well and do another proxi scan and it all worked.
So for anyone else struggling next time - make sure you enable both cruise control and speed limiter before the proxi scan 👍
