MRT
Hi my Fiat Doblo taxi has just failed its council test ( MOT) on emissions any one got any ideas of any common problems what could cause this.
Hellcat said:You got the results of the test? They should give you a printout detailing the readings. This can let you know in what way the engine is running out of parameters.
Hellcat said:Go and ask them for the printout.. If you havn't paid them yet try going somewhere else. I had a garage fail my old diesel tipo due to emissions. When I took it elsewhere it recorded the lowest smoke result they had seen.
I'm guessing since its a Taxi that its a diesel.. Give it a new air filter and if it didn't look too clogged give it a bottle of diesel injector cleaner.
MRT said:Wish I could take it somewere else but been a taxi it has to be tested by the council Mot testers.
Will try changing the air filter today put some of that millers injector cleaner in yesterday. Is it normal for your car to run like its got a rocket up its backside with that stuff in as mine is.
