Electrical Fault
Electrical Fault
J
John
I have an electrical fault that has appeared in my Brovo. When I indicate to turn left and brake the indicator stops and when I take my foot off the brake the indicator starts again. Also when the lights are on and I indicate the NS circular tail light apears to dim in time with the indicator flash in its centre.
Can anyone help me find what is causing this??
Cheers.
JL
Earth Fault
Almost certainly an earth fault. This can cause all sorts of wierd things to happen. Check the connectors at the back of your rear light clusters to make sure one hasnt fallen off. And check the connections on your battery. Other than that it could be difficult to find the fault as there are hundreds of electrical connections.
N
2
434
M
C
2
832
K
K
1
504
M
T
1
1K
Sabre 23
S
J
3
358
Dark Lurker
