Big mistake!!
Pulled my working model apart and now I can't get it back together! So I have 2 that wont work!.
The motors are fine, even if one does have bad bearings in it.
The issue is how the drive mechanism connects to the motor. In the early model, on the right of the photo, it is a plastic fitting that at one time had 2 pins or a ball bearing that went in the grooves of the spiral tube, this was held on by the plastic surround. You can see the two holes where the pins/ball bearings went, and the plastic clip above the screwdriver.
The later model had a metal U shaped section, in place, (I wish i left it there!) with ball bearings inside it and held on with the 2 metal clips, between the screws.
I am trying to figure what I can use to drive the spiral tube but not hold it too tight to stop the motor. I don't want to pull another one apart and wreck it too, at least not till I figure how to make it work again.
I tried using larger ball bearings and cable tying them in, unsuccessful!
Might try a modified idea of this next.
You can see the size of the holes I tried cable tying the ball bearings into in the 2nd picture. The small dots are the ball bearing out of the later model U piece I mentioned above.
Any ideas/suggestions people.
