General  Electric window module
Moho2000
Cornwall
Dose anyone know if you can get the small control circuit that fits in the motors. fiat ducato 2006
Model
Flat ducato
2006
I am sorry that I cannot help directly. May I point out that 2006 was a model change year, when the x250,replaced the x244 model. I do not recognice the part as being appropriate for my 2006 x244, so I assume that yours is the later x250 model. Check first three numbers of VIN to confirm. If you do indeed have an x250, I suggest that you quote the 250 model, so as to remove any ambiguity.
Just incase you go for a replacement from a scrap yard, there are two versions of the window control module.
One has the electronics (as per yours) and one has no electronics at all.
If you fit the second type there is a good chance you will either blow fuses or burn out the motor, so be aware.
If you do not find a replacement module (which I did not), then if you are happy with modifying wiring and electronics then
this is a good replacement: https://www.ebay.co.uk/itm/181256324507
Vendor was happy to confirm wiring for a Ducato.
The unit works well but note that the full up/full down trip does not work with this unit, so if you keep your finger one the up/down
control things will get hot at best.
I have this unit fitted to the passenger side and has worked fine for the last few years.
Martin, GM6VXB
