Effective locking wheel nuts...
A
Anders
How effective are locking wheel nuts at stopping/deterring would-be wheel thieves?
Theres been a few cases just recently of people having their alloys nicked overnight by the local moron brigade from the private carpark outside my flat. I've got locking wheel nuts on mine and wondered whether they do stop people taking your alloys or whether they're just to stop the opportunist 12 year olds??
A decent set of locking nuts will deter most opportunist thieves, as they just dont have the equipment or time to take them off.
They can be removed by hammering a slightly larger socket over the nut making a tight fit, then undone in the normal way. However they need extra tools to do this, a secluded area- as it takes time and banging the socket on x4 will make noise. If you have a decent alarm with shock sensing on it, then banging sockets onto your wheel nuts will prob set it off, but if youve parked it in a secluded area no one will hear/care.
Also ive heard of scallies welding conventional nuts onto the locking nuts, then undoing them as normal.
Another option is for them to steal the car just for the alloys, so make sure you have a decent alarm/immobiliser and steering wheel lock. Ive heard the factory immobiliser fitted by fiats is quite good, but a good alarm with shock sensing is a must if you have alloys.
One final point, all of these security measures are useless if you leave your car keys in a visible place in your house, such as on a worktop,or hung up near your front door. This is a bad idea as scallies have started breaking into houses just to get the car keys and then driving off with your car.
One ingenious scally around my area was stealing cars by getting hold of the car keys using a fishing rod through the letter box! He got busted when he was caught around midnight in someones garden with a rod.
Another good idea is to buy 2 sets of locking nuts if you have expensive alloys, it then takes them twice as long to get them off.
It doesnt take them long to get them off anyway as they usually work in teams of two or four, but its worth a try.
Hope this info is of some help.
Tony
Locking nuts
A guy near me had his expensive alloys pinched even though he had BMW locking wheel nuts on, after checking up, it seems he found out that BMW only made 12 differant locking nuts, so if a scally bought all 12 sets, he could undo any BMW locking nuts in sight
forntera
i used to have a wonderfully crap vehicle called a vauxhall frontera. when in the garage for new brakes i forgot to bring the nuts. no problem says the mechanic jamming a normal air hammer on it and whizzing them off like normal. not what they seem.
riclemus
a little story
my old bravo got broken into, they didnt take anything, but they went in my glove box. i thought they were after my stereo but they toojk nothing because they didnt find the front for my head unit.
A week or so later my car was making a banging noise, i thought the driveshaft was on its way out so i took it to a garage. 10 minutes after i got home he phoned me up saying he had fixed it, turns out they had loosened all my wheel nuts, then found the locking nut so run off without retightening them. I had only 1 wheel nut holding my wheel on.
They may be easily removed, but they are a good deterant.
Best Deterrant.
This was one of the pearls of wisdom given to me by Kent Highway Patrol during the training course.
Get a machinist to make you a set of four wheel bolts with opposite (i.e. Left Hand) threads. Put one one each wheel and they will never be nicked.
Even if you knew one was left handed you would be threre for hours figuring out which one it was. So simple, like the best ideas, but effective.
Did it once - on a Cortina of all things!
So if you have expensive alloys, £20 for a machinist is nothing!
However you need to use lock tight on the nut and it makes it a bugger to get off yourself!
Let me know if you try it!
Nige
Thanx
Thanks for all the tips, stories etc.
When mine returns I'll be seeing about fitting a decent alarm and I do like the sound of Nige's left-handed nuts...
Cheers!!
M
4
661
M
R
785
R
C
6
446
M
G
5
976
sam ng
S
