Technical  Ecu
Technical  Ecu
Steve1958
Dartford
Hi, I wonder if you can help me , I believe I have an issue with my panda 1.2 2008, I have changed the coils due to occasional misfire. I think I have a ecu issue. It's a magneti marelli 51793116, if I purchased a replacement from a breakers would I need to carry out any other programming. Thanks
Yes needs to virgin to accept the CODE sent from the body computer
Base models then just normally just work
Can't be done with most home software
Very rare for the ECU to fail
I know of 1 in the last 10 years or so
Wiring loom is fairly common fault though
But you have to step by step walk through it logically
Thank you, I disconnected the ecu and reset fault, driven 5 miles with no issues, I think it just dirty pins possibly, is there a good contact gel people use on these pins connections
People swear by Deoxit D5
Does depend what I am doing, circuit boards coved in a spillage might get a swim in 99% isopropanol for example
For general contact cleaner Servisol Super 10 is what I used for years and is half the price
But there are alternatives at £5 but never used them
Any error codes with the misfire
