Technical  ecu & wd40
redruth cornwall
Hi everone I,ve just read with interest the thread regarding the engine light coming on I,ve had the same problem for a couple of months on my 1.3 multyjet idea dynamic the local fiat dealer has reset the light with no faults found. Could someone explain where the ecu are and if the connectors are disconnected to spray with wd40 will it have to go to the dealers to reset any faults that disconneting the connectors on the ecu may cause. I would like to try this if the problem persist
thanks dave
Hi
no this is what confused me as when i read the scanner code as transmision pressure solenoid stuck on. When fiat dealer put it on their big fancy diognostic scanner the same code came up but it was nothing to do with the transmission seems that fiat has their own code when you have a code in the 700s thanks for your quick reply
hi, its possible just seems a coinsidence that the codes were simalar the car is going great at the moment I love um if they still made that model I would get another new one tomorrow.but I'm still keen to know more regards to the wd40 solution
regards dave
hi dave have you figured out the ecu / wd40 thing yet i have the same problem and i cant find ecu if you know this please let me know thanks
