Technical Ecu problem 1.2 8v 5dr
Anekis
Athens
So i have a 1.2 8v 5dr punto as my first car and lately its been acting up. I took it to my mechanic and the ecu is bad. To fix it through official shops would be a bit expensive for my standards so after some reasearch I found out that self programming ecu exist but the links i found out didnt exist anymore. Could someone direct me to what exactly i must buy? Thanks :)
you need to get a virgin or virginised ECU for your car. I think you are looking about 80-100 pounds for that however
Thank you very much. The shops i asked all wanted around 200-250 so this is much better
Follow up question because I am one step before buying it and i dont know a lot about the topic. I did a little search under the hood and found out that mine has these codes on it. The one above will match correct?
