Technical ECU OBD
Technical ECU OBD
Nora
I was wondering if it is possible to read out the ECU on my 1988 fiat panda, (1000ie 4x4) with an OBD? I haven't found anything about it online but I'm still curious.
Michiel
I'm afraid it could be impossible.
Try finding if flashing a used ECU is possible, they should be a little bit easier to get from a breaker. No idea how much information they contained so long ago, perhaps replacing by another one from the same engine is possible.
It should have some numbers on it. Any search results appear on the internet?
What happened that you're looking for a new ECU?
It seems to me it's a fire engine. Same were used in Unos, probably also Puntos.
I have no idea if it could be swapped. Nowadays it's rather impossible, but 40 years ago those modules were dumb :D
Looking over the internet I've found several companies stating they repair different ECUs for different FIATs. More input is required. But it could be a solution. Depending on what happened to yours.
