zoli
Hi guys,
I'm curious, has anyone tried fixing the engine ECU of a Stilo 1.6 Petrol at home by baking the PCB board of the ECU in the oven for a certain amount of time to fix the famous " Loose connection, ASR fault, ABS fault, High Coolant Temp, Engine Fault, ect. " errors that come and go and are definitely not caused by a bad battery or other electrical faults ?
After 5 years of steady and perfect service our Stilo 1.6 Petrol decided to flip us off by leaving me at the side of the road (thankfully in town) with the various and intermittent faults that I just call " dashboard Christmas lights errors " which are most probably caused by old and worn solders on the PCB of the Engine ECU.
I did of course the obvious, cleaned all " known roots of evil " connectors with contact spray, took out the fuse box and cleaned it, cleaned the major ground and 12V line connectors around the battery, checked the battery which was more than good, checked the charging voltage which is rock steady and sufficient, I could not find no apparent corrosion marks on any of the major connectors, all lines seem OK, engine ECU connector pins also seem OK, so I'm left with no other (or very little) causes that can manifest themselves in these all kinds of lightshow effect on the dash which sometimes do pop up, other times I can drive the car fine, some times the immobilizer inhibits me to start the engine, other times it just comes up during engine start but disperses soon and off I can go.
My electrician friend tells me (oh, and my mechanic as well) that all things said, this points to the ECU failing, most probably the worn solder points under neath the chips in on the PCB.
In the IT industry, in which I work, there is a good old last resort method of fixing bad graphics cards, ssd's, mother boards, by baking them at just about the melting point of the solder for about 5-to-10 mind and letting it cool down, and voila
in most cases it fixes the old worn solders and the thing comes back to life. I did it myself that's why I can vouch for that method.
Now, I'm curious, could that also work on the engine ECU of the Stilo ???
I'm either looking at having it fixed by a professional or finding a virginized one anyway, so I'm thinking of giving it a shot.
What do the forum goers think ?
BR
Zoli
BR
Zoli
