John gibson
- Joined
- Feb 3, 2021
- Messages
- 5
- Points
- 2
Are 2007 wheels interchangable with 2001 on a DUCATO campervan?
thank you,i believe i have a [light chassis] as under 3.5 ,if tyre sizes are the same as what i have on my van,will stud pattern be the same.i am looking at some wheels with tyres on [market place].Ducato s can come with a variety of wheel sizes. Eg in 2017 15inch wheels with pcd 118 or 16 with pcd 118 (light chassis) or 16 inch130 (maxi chassis)
So what have you got / need and the alternative?
thank you jackwhoo,The wheel bolts are significantly different threaded sizes between heavy chassis and light chassis.
The 2007 wheel is most likely 15" with 5x118 bolt pattern and offset ET 68.thanks for your replys,i believe i have a light chassis as under 3.5 in weight.
Confusingly in UK most Maxi/Heavy vans are 3.5t - so that doesn't automatically tell you which van you have. The clue is usually the plastic wheel arches above the wheels - only Maxi/Heavy vans have them from factory. If you have a panel van, or even the cab from the original van, a Maxi/Heavi will have them.thanks for your replys,i believe i have a light chassis as under 3.5 in weight.
I have an L3H2 light in UK and it is 3.5t. I believe most L3H2's light are 3.5t?I think it's much safer to check in EPER, someone could have added the plastics wheel arches, or it could have been added at the factory as an extra option.
Maxi can be 3,5 t or 4,0 t depending on the market.
Light chassis should be 3,0 t.
When you check in EPER with your VIN, in the 443 SUSPENSIONS AND WHEELS » 44316 -> WHEELS » 44316/00 WHEELS section it will tell you the rim size and the stud part number, with which you shall find the correct size.
On my 3,5t 2012 x250 maxi I have 16" wheels, the rim size is 6JX16'', 5x130. The studs part number is 1351203080, they are M16x1,50, lenght 64/29 mm, 21 mm socket.
As far as I remeber, 15" tires have M15 studs.
I don't think there is a way to put heavy wheels on a light chassis even if a person wanted to. The bolt positions (PCD) is different, the bolt diameter is different. Nothing would fit.Unless someone has put "heavy" wheels on a "light" chassis
To spread confusion my x244 LWB PVC with a MAM of 3300kg has alloy wheels. The wheel bolts are M14 with 24mm across the flats."Heavy" chassis wheel bolts are m16 thread, 21mm across flats hex head.
"Light" chassis wheel bolts are m14 thread but also 21mm across the flats hex head. So if you want to know you have to remove a bolt and measure the thread diameter
Pretty sure. As far as I now the wheels and bolt patterns haven't changed on Boxer/Relay/Ducato between 2007 and present day. Heavy/Maxi has PCD 130 with centre bore of 78mm and M16 bolts, light chassis PCD 118 with centre bore of 71 mm and M14 bolts.Hi,
Are you 100% sure On the x250 ducatto the pcd is different between light and heavy chassis?
I recently had to change rear hub and discs on an x250 -turned out to be light chassis- but (from memory) the hubs are identical apart from wheel bolt thread size.
So putting light wheels on a heavy chassis would be a no go if bolt holes too small for m16 bolts
But heavy wheels on a light chassis may be possible though not necessarily safe if the cone on the m14 wheel bolt doesn't engage fully with the m16 cone seat in the wheel- I would say just don't do it , instead be safe.
Best wishes
Jack
Sorry I need to disagree with this statement. I have a 2024 Ducato light panel van conversion. It is certainly a light chassis, just obvious things like the presence of single leaf springs is the biggest giveaway. But if I take out a wheel bolt I21mm AF head) and measure the thread outer diameter, it is roughly16mm. In my understanding that makes it an M16 bolt. So I’m reasonably confident to say that factory fitted alloys, on a light can / do have M16 bolts. This may be different for different for steal rims, no sure. But saying that my spare is a steal wheel so I now need to check if it correctly seats with the M16 bolts."Heavy" chassis wheel bolts are m16 thread, 21mm across flats hex head.
