General Ducato pressure switch
Mully59
Does anybody know if the air con pressure switch can be replaced without all the pressure escaping when it’s unscrewed. 2013,2.3. Thanks Mully59
Unlikely :eek:
Wants the system 'vac'd out 1st
And if you are opening the system..
You really want it pressure : vac tested before refilling
What pressure do you currently have ?
Hi, I had it pressure tested all ok, old refrigerant removed and new oil/leak test colour put in and new refrigerant put in but still not working, they removed new refrigerant and didn’t charge me, said possible faulty pressure switch. I just want to remove old switch and fit new one before they refill system,just wanted to make sure it won’t blow off when I unscrew it.Thanks for the reply.
