Technical Ducato newbie.2015 x290 turbo boost pressure sensor faulty
Dave Tring
Hi all, I need to replace this sensor,code coming up is p0238 which was diagnosed when I was broken down by the AA .it seems simple to do but how the hell do I get to it? If I am correct it is on the intake behind the throttle body and under fuel rails ect ect .just one or two small bolts holding it down and unclip the plug simples but I can’t physically get to it.if I like to do it myself if i can .any help would be appreciated please.regards Tringy ps it’s on a 2015 x290 2.3 150 bop motor home.cheers.
You need to remove the the front slam panel "you will need to prop the bonnet up" to gain access then remove the Throttle valve three allen key bolts 2 are easy to get at and the 3rd one is underneath and out of sight which makes it awkward to remove
then remove the throttle valve to get access to the MAP sensor whilst its all off its worth while cleaning everything
Thanks for your reply, I did not want to disturb things until I was sure
