Technical Ducato gearbox end cover plate
WelshTom
Hi everyone,
I have a 1998 Hymer motorhome which is based on the Ducao. It has the 2.5TDi engine (Sofim/Iveco 8140.47). The gearbox end cover (next to 5th) is rusting through and I would like to replace it before it goes totally and kills the gearbox! I believe the part I need has part number 9632808880. The only place I can find one is in Europe at a cost of £160ish but before I take the plunge and order it I was just wondering if that gearbox was a fiat-only part, or if it was used on any of the other vans that used the same engine?
Many thanks
This is a photo of the part in case anyone thinks I have the wrong part number!
Scrap that, it's not the part number I need! I've just removed the cover and it's totally different. Can anyone help me find out the part number I need? I've attached a picture below of the actual part in case that helps.
Hi everyone,
Many thanks
Hi Tom I’m also looking for the same part but there doesn’t appear to be any available in the uk ! Could you send me a link to where you saw them in European market as i also may have to resort to buying one from there ? Regards Richard
Hi @ROBROY10 , it turns out it wasn't the part I needed after all. Part number 9632808880 was for a different gearbox. If that is the part you need it can be found here. The part I needed for the 8140.47 engine was not available anywhere so I ended up taking the one I had to a local engineering company who were able to patch it up for me. Cost me £75 to have the patches welded over it and they then zinc coated and painted it for me and it looks like it will be good for years to come 🤞
Thanks for taking the time to reply ! Don’t think this part is to be had anywhere ! I will probably have to do something similar ! Cheers
