Technical  Ducato error code P0403. EGR valve cleaning DIY help
JoseBenitez
Pwlhelli
HI everyone!
I have a Fiat Ducato 2007 3.0 160hp and the typical engine light turned on... because the EGR valve I suspect.
After reading the OBDII, the error P0403 appears persistently.
I think that I would need to clean the EGR valve after a lot of reading, and also, because it fails to start on the first attempt and then it starts.
I would love some guidance on how to do it by myself. I have some repair manuals but I am not sure if I have the correct one or not.
Has anyone been successful repairing this issue on their own?
Thanks in advance :)
HI everyone!
Any responses?
The start point with this is to actually know if your EGR is working or not. Only physical check will tell if it is operating. I disconnected the throttle body and shoved pipe up EGR cooler to be able to always be able to blow through it. So stuck open.
