Technical Ducato engine battery replacement
Hi everyone, I recently had to replace my airbag module. The diagnosis report I got said low engine battery voltage. I'm goint to replace the battery soon. Does the batery need alignment after replacing. Thanks.
There is a procedure for disconnecting the battery in the handbook
You just turn everything off, shut all the doors and wait a minute before disconnecting the battery.
As I understand it, this is to give the computer time to shut down
Otherwise its like pulling the plug on a home PC before it shuts down
If you are lucky you will get away with it - but if you are unlucky you won't, and some sort of damage will be done.
