Can anyone tell me where to find the reversing light switch on my 2006 2.8 jtd automatic?
If it's relevant, the vehicle is an Elnagh SeA CPT motorhome (lhd).
Many thanks
Hi
I think you will find like most Automatic Transmissions the reversing light switch is part of the "inhibitor" switch normally located on the position shaft near the side of the Oil sump (the big rectangular plate on the front of the transmission case).
-See item Number 190 in the attached PDF exploded parts drawing of the ZF4HP-20 Transmission.
From that exploded parts drawing & also from the repair manual it looks to be located on the front side of the transmission near the top LH corner of the inspection "oil sump" plate.
Hope that helps
