Technical Ducato 244 2.8 JTD Oil change - automatic gearbox, advice or guide needed
Denmark
Hi there guys.
I am about to replace my engine and aut. gearbox for a slightly lesser used model.
But I have trouble finding any data on how to change the oil and filter in the automatic gearbox.
I will be preparing the new-to-me (used) engine and gearbox prior to installing them.
New timing belt, pulleys etc.
Any advice on that subject would be greatly appreciated.
Hi there guys.
Hi Parkhave
First you haven't said what year yours is & what engine it has, helps straight away?
Just looked at your profile & its a 2006 2.8 JTD Auto.
Not completely clear on what you are trying to do, Replace an old worn out engine with a SAME 2.8JTD common rail engine & 4 speed auto?
These were fitted with a ZF 4HP20 Auto transmission
I have attached both the ZF4HP20 training manual & also the repair manual for the ZF4HP20.
In the Training manual on page 27 is a picture of the filter & from 31,32 draining & filling the oil etc.
The filter on page 129 of the repair manual looks to be replaceable either through the large end plate or via the sump & valve body??
Hope this helps
Cheers Freespirit
  • ZFAUTO_ZF4_HP20_training.pdf
  • ZF4HP20 repair manual.pdf
