Technical  Ducato 230 gearbox
songless
Almaty
Hi guys.
I have a Ducato 230 2.5TDi/1997 with 20KM20 gearbox and spare gearbox 20KM21
So what is the differences between this gearboxes?
I may be telling you things you have already tried but a couple of suggestions: EPER is a good starting point. Also, have you tried googling the numbers. It should come up with a number of sellers (mostly abroad) of 2nd hand and or recon boxes. Some have a list of equivalent numbers, whether they are accurate or not is the question. This is where you have to form a judgement looking at as many sources as you can find. The German parts seller A. Augustin (can't remember full name) is a very good source of equivalent part numbers. If it's any use, mine is 20KM57 (from memory) and is from the 2.8tdi.
Thanks for advice.
I had already googled gearbox codes and its results led to various auto parts sellers. I should ask sellers.
I got answer from barbetten.com that there is no difference between these gearboxes.
TDI 2.8 SOFIM BVM MG5T 20KM09 20KM13 20KM20 20KM21 20KM29 20KM31 20KM32 20KM81 1000+1400 CP13X68 2222T5 20KM31 20KM32 20KM81 1000+1400 CP13X68 2222T5
Question is closed.
