Technical Ducato 2.8JTD 2003 Radio upgrade facia panel help
Do you need help unlocking your radio?
Get your code instantly using our radio unlock service 🔓🎶
Suffolk
Ducato 2003 2.8 JTD
Does anyone know if a facia panel to upgrade the radio to a double din unit is available for this model ?
It is an unusual radio, no one Ive asked has seen one like it
Search the usual places with no joy
I think that your photos are showing a "connect unit", which as you have found are rare indeed.
A double DIN cowl was produced, but discontinued.
You may find this old thread interesting. Also some Italians have adopted a DIY approach which can be seen here.
Then there is Ebay which may be seen here.
Ducato 2003 2.8 JTD
It's a Magneti Marelli Connect Nav unit. It was fitted as standard to some higher spec. Ducatos.
The vertical slot on the right takes an old style credit card size SIM card for the built in mobile phone.
The built in navigation system uses a CD ROM for its data source.
If you want to explore it further, you can download the user manual from here: https://www.fiatforum.com/downloads/ducato-244-connect-nav-10-02.115/
