Hi There,
2013 Fiat 500 L - 1.3L Diesel - Stop / Start - SemiAuto
Battery replaced, and ground connections cleaned up. Now have a car that has no fault codes on the dash. However, my main issue is long far solved.
When I put the car into drive, I see on the dash selecting 1st gear. However giving the car some revs to move forward, the car eventually slams into gear with quite a shunt and stalls the engine. This is quite a serious problem, and I won’t be doing that again, but can someone point me into the right direction for a fix.
