they're all CAN faults relating to a bad communication between different ECUs.
NCM = Engine ECU
NBC = Body Computer
NGE = EPS ECU
NFR = ABS ECU
U1601 will be a general CAN Comms fault iirc
the other 3 will be failiue of comms between ECUs. the common denominator being the Body Computer. i wouldnt worry too much about any of them unless you're getting ENGINE,ABS, STEERING failiure or Loose Conection flicking up on the dash/cutting out. CAN is usually the first thing to be cut in low voltage situations such as cranking on a really cold morning or after the motor has been stood for a while. they can also be thrown if you stall it or turn the ignition on and off rapidly for whatever reason. theres all sorts of other reasons they MAY be thrown too, i just cant be bothered to list the most common.
CAN faults are notoriously hard to diagnose, especially if they're stored. Personally, I would delete them and not worry too much unless it affects vehicle performance or crops up repeatedly.
