Technical Driveshaft
bikes-for-me
Newark,Nottingham
Been busy doing my motorbike project since i last put the diy clutch thread up. My partner was driving the multipla and the n/s driveshaft gave way, it came out where its bolted by six m8 bolts engine side.
When car was towed home had a look and 2 bolts had shared off and 2 had damaged the fixing bolt thread , i managed to clean the 2 damaged thread holes up and drill the 2 broken bolts out. On cleaning the thread on where the bolts had broken my tap broken while doing the last one :mad: , it snapped well in and i brought myself a set of cobalt drill bits to drill it out.
They wont even touch it , i thought it might be better to take the driveshaft complete off the car, already took it off wheel side to 6 xm8 fixing. There are 4 x 13mm bolts that hold a plate on engine/gearbox holding the driveshaft mount, 3 are easy to get at and one is well tucked away , you can not even get a spanner in there to undo it , seems you have to take gearbox off to get at it.:bang:
In the end i repacked the old driveshaft and put the end cover on which had knocked off , and i fitted it with only 5 bolts instead of 6 and plenty of thread locking stuff. Going to give it a week and recheck bolts , if they have worked lose might try slightly longer bolts and put a locking nut at the back , if there is room.
Anybody had the same problem , and the magic qestion is anybody took the whole left side driveshaft off , and if so how did you get the gearbox end off.:confused:
I cannot remember just how it comes out, my old metro :eek: was held in place with a split pin through the shafy but think the multi may just pull out:confused: though iam sure you tried that allready.
If it goes wrong again it may be an idea just to get a complete s/hand shaft ive seen new ones on ebay complete for as little as £45 buy it now.
I can feel another quality "how to do " coming on :D.
Gotta wonder why it came loose in the first place, do you have an unbalanced wheel or did you not use lockthread last time it was off.
:eek: Ran out of lockthread when i put it back , and other half wonted car quick, so put it back without.:bang:
I think the driveshaft just pulls out of gearbox , but there is a 4x 13mm bracket holding it on gearbox and one bolt you can not get on it even with a spanner. Seems like you need to drop gearbox to get to it which seems silly. Just hope 5 bolts will be ok , might get longer bolts and locking nuts just to be safe.
Got to do cam-belt , so that might be next how to. When do it i will be changing the lot plus water pump.:D
It should be fine, most 'critical' parts are usually 'over-engineered' with a decent safety margin, to allow for neglect, wear, damage, and general deterioration.
I'm not 100% on this but I believe the flange is just held in by a circlip internaly. Once you've removed the shaft put a chisel behind it and whack hard with a hammer. Don't undo the 4 bolts!
