Technical  Driver's Side Windows Close - Issue
jolly green giant
Hi there. Got a strange issue - the driver's side window no longer closes unless I keep myfinger on the up/down button. It works fine opening - I don't have to keep finger on button to open - but I do to close it. Furthermore, using the key fob to remotely open the windows no longer works for the driver's side, only the passenger side.
I'm not sure if this is a mechanical or computer issue, but it seems very odd. Any ideas please?
Thanks.
Thanks.
Having to hold to put the passenger side up is normal on some models, like the 500 for example, so perhaps its always been the case on yours and you've not noticed?
Re the remote operation, might be worth disconnecting the battery to 30min to reset everything and and then give it a try?
I had this very same issue once on my fiorino van, but the next day it was ok again and has been ok ever since.
But i can confirm that your qubo does have auto up, and should work on your remote when you lock up
LUIGI
Have you disconnected the battery recently? The windows will lose their memory if the battery goes flat or is disconnected..
Try this. With the window closed push and hold the window button until the window is fully open, then push and hold the button until the window is fully closed. This should reset the one touch open/close.
I took my battery out on the weekend and both my windows lost their memory. The passenger window only required me to do the full open/full close once to regain its memory, the drivers side was a bit more of an arse and I had to do it several times until it started behaving.
Hope this helps.
Hope this helps.
Good point Envy
I had to do the reset method when i fitted my wind deflectors, as the passenger one met a bit of resistance at the top and went back down again, but after a few up and downs it sorted it self out.
LUIGI
both my leccy windows have a mind of their own, I just put it down to the electrics being Eytalian/Turkish and crack on with things (with some choice anglo saxon words thrown in :slayer: )......I miss my deux chevaux .:D
