Styling  Driver seat repair
Hi guys, I got new bottom foam part for my Bravo and I was wondering if any of you had removed the cloth cover from the seats.
Today I was cleaning rear seats, so I removed the cover from metal holder, but the cloth was stuck on foam part with some wires. I guess it will be the same for front seats, so how do I remove the cover completely?
The new foam cost me about 15€, but I don't want to damage something there.
I finally had some time to do it and it went OK. Front seat is hold by 4 bolts T40, seat belt by 1 17mm and there were 2 connectors under the seat. They can be removed using twi flathead screwdrives.
Bottom piece is hold at front by one long clip - just pry it out, at rear there are 4 hooks - also just use force to unhook the seat cover. On both sides are 3 clips - you can push them from inside.
Then you should be able to remove foam with cover as one piece. Cover is held by 8 clips, that are "C/" shaped, so you just need to unhook them carefuly, while applying pressure to the clip from bottom.
I wasn't able to remove long wire from seat cover, so I had to wash it by hand. Then I put clips back to the new foam, clicker the wire into them and put it all back into the seat.
In photo you can see the 300 000 km difference
Yes, the left side was completely collapsed. Now I can finally sit properly
Would it be possible to put Some aftermarket heating elements under it? Or are the mentioned wires an obstrution?
