the hobbler
Distinguished member
- Joined
- Jul 25, 2012
- Messages
- 4,422
- Points
- 1,112
I have purchased this drive-shaft kit from D'Angelo---can't knock the quality, or the service that I got from them.
I've always fancied those Dave. Is that a set for the driven end only? I considered them but as far as I can see they are inteded to over-ride the inherent weakness of the rubber/aluminium coupling. Doesn't the tripod still have to fit over the driveshaft splines and be able to slide up and down along it. I know it would be very helpful that it is properly encased in a rubber boot filled with grease but is it as good as a proper, modern CV-joint?
I’ve read about the tripod on the Italian Fiat forums but have never soon a picture of one, much less one for sale on the internet. Where can one be obtained and do you think it’s worth the effort and expense of installation?
I looked on the Axel Gerstl site , they are listing them and showing them in stock at €397 a pair.
Hi All
The kit looks good with proper steel(not cast iron) flanges that are heat treated too for strength.
Tim
You can always fit the tripod kit, this is a spare set I have![]()
I seem to remember some debate about this potential issue some years ago as the possible slight cushioning of the rubber filled coupling had been taken out of the equation but was dismissed at the time.
Good to know. Looks like it’s an easy to install bit of extra insurance.
The new axles and flanges arrived from D'Angelo Motori and they look glorious. Here's hoping that this is the solution to my woes.
