draining the radiator
Dan
Ok im going to drain the radiator and fill it up from clean with anti freeze stuff. but i cant find the screw that drains the radiator. On my old astra it was just to the left hand side which you could undo with a wrench but i cant find it on my bravo. its a 1.6 16V just incase it makes a difference???
You'd be better off draining down the whole system rather than just the radiator; then filling up with a mixed solution of water/af.
How do you do that? IE: Where is the screw or bolt that you take out to drain the system?
Re: Re: draining the radiator
There isn't one. Unless the water is brown, leave it well alone.
F
957
Frank
F
M
2
206
M
C
636
ChrisKnottIns
C
