General Draining the coolant system - Any pointers?
Ratters
Tina The White Cinq
Melton Mowbray
Hi all,
I am going to drain the coolant system on my '94 Cinq because the radiator needs some radweld in it and there is come air in the pipes, etc. So just wondering if anyone cold give me a few pointers on how to do it, etc?
If you want to do it the easiest way, pop the bumper off first.
Carefully remove the bottom rad hose over a large bucket. Water will go both ways so I use a plastic 5 gallon drum with the side cut out.
I really wouldn't want to be putting radweld in as a permanent fix. Rads are now cheap enough, particularly if you speak to Fluffy, and if you join the club they are even cheaper.
Thanks rallycinq. You are like Yoda, when ever you talk, what you say is so wise :worship: all hail rallycinqyoda :D
i dont like cats :)
