A possibly simpler method is to pressurise the tank and simply let it drain out. I have found that If I have had my engine out, it usually means that I have to disconnect the pipe to the fuel-pump (and aim it into a fuel-proof container) get my small electric tyre-pump out and pressurise the fuel-tank by putting the hose from the air-pump into then tank, and simply sealing the filler neck by holding rag around the air-line. When I can hear the fuel tinkling into the container, I stop the pump, run round to the back of the car and re-fit the fuel hose onto the pump. I have also used this method to empty the tank to a greater degree when I have emptied the tank at the beggining of winter when I know that the car is not going to be used for some months ( to fit new drive-shafts to the gear-box, replace a snapped crankshaft etc, and other normal things!). If when the fuel stops running you fill up the tank with fresh fuel and give it a good run, all should be OK.
