After a week of deep cleaning my newly bought Seicento S today I wanted to tackle first mechanical job.... My clunking drivers door.
Looked up YouTube etc for visuals on same.
General consensus was either door pin or door latch restrictor.
Tapped out door pin.
Ordered a box of mixed size roll pins from local hardware but none seem to fit the top or bottom holes on the car body side.
QUESTION 1
DOES ANYONE KNOW WHAT THESE ARE CALLED, WHAT SIZE DO I NEED AND WHERE CAN I GET THESE Online?
Unfortunately The Mrs arrived home from shopping and I stupidly pushed in my door without the locking pin and the latch extender went right back inside the inner of the door.
So I decided to remove the latch itself from the inside of door to see if there was anything obviously wrong on same. I unscrewed the armrest 3 x T30 screws and a hidden clip. Couldn't figure out how to remove window handle but gather per another YouTube video that there is some kind of pin between winder and inner black plastic cover that needs to be removed so that you can wiggle the handle off. Removed door cover and carefully pulled back the glued insulation stuff. Removed the outer screws and held on to the restrictor for dear life so it did not fall inside the door. Got it out but can't seem to get it to extend back out so that when reattached inside the door it can reach where the PIN goes through it.
QUESTION 2
DOES ANYONE KNOW HOW TO GET IT TO EXTEND?
I've ordered a new one on Autodoc but still curious how to extend it.
Sorry for the length of this and thanks in advance for any suggestions re Door Pin and how to Re Extend the restrictor.
QUESTION 1
QUESTION 2
