Technical  Door problems
Chrispy77
Barrow in Furness
Hi, any have any idea why the passager door won't lock? Fita 500 Lounge 1.2L 2015.
So6nds like the actuator is working but I can even push the lock in from inside the car??
Any help would be much appreciated
Can you test it with the door open by pushing the lock latch part into it's second position using a screwdriver, then lock car with your remote still with door open and see if it locks then. If it does it may be adjustment, failing that you may end up needing a new lock.
Note release the door catch fully to it's open position before trying to shut the door normally or you will damage the lock.
Just tried that but nothing, thabksnfornthe advised.
The handle on the inside is in the permanent locked position, but still open lol. Could be an adjustment issue??
