Hi
The passenger side door of my 1992 Panda is jammed shut and I was hoping for some help/advice...
The symptoms are that the door is jammed shut like (for example) the seat belt buckle has got shut in the door and the door isn't completely closed. However in this case the seat belt buckle is not caught in the door.
The handle on the inside of the door moves but can't return to its proper position (and of course doesn't open the door).
With the door card off, the linkage from the inside handle and the locking knob are both unable to move freely. The exterior push button itself moves in and out freely, but the key will not turn fully because the linkage won't move. I am confident the lock itself is not the problem.
I think the latch mechanism is jammed somehow, but I can't see enough to work out how (or if) to un-jam it.
The existing threads I have found relate to door problems being fixed with the door open.
Is there a way of taking the door off from the hinge end?
Any ideas and/or moral support gratefully received.
