W
Waderider
Was at the scrappies today attempting to extract the quality door handles I have mentioned in other threads.
I had a problem with the lever (or pins) that connect the the external handle to the internal handle, and the internal door locking button. Basically they were total barstewards to disconnect. I lost the first pin retaining clip down the door innards, attempting to remove the second (the one the pdf guide recommends tackling externally), the actual metal tab on the lock barrel retaining metal moulding broke. So the bit that holds the key barrel is damaged.
At this point I snuck out of the scrappies.....thank god that hadn't happened when working on my own car!
So how do I recover this. I'm going to go back tomorrow for the other three handles, so I guess I'm obliged to take and pay for the one I've damaged. The question is this.....I noticed that the lock barrel retaining mechanism is attached to the moulded plastic part of the barrel by three small screws. Has anyone any experience of replacing this part, or put another way, has anyone had success ONLY replacing the plastic and rubber parts of the handle.
It's not how the job is described in this sites guide, and all ebay pictures show the handles with the lock barrel holding metal components attached.....it's a long shot but does anyone know?!
Any tips on how to successfully remove the pins and plastic retaining clips without force also gratefully received.
Jeff
Destroyer of scrap Brava (door handles)
Jeff
