only reason i said ball joints is i had a similar problem on a 5 gt turbo. amazing how gradually these things can build up and its only when you get them replaced you realise how bad they were
wishbones are easy to sort on a tipo.but give the bolts a bit of a soak first.Bushboy said:well im sure the fact that my passenger side lower arm rear bush has about 5mm of give doesnt help matters much
will get that sorted at some point..
are they easy to swap? not just the bush, the whole arm
