Technical  Doblo remote Central locking wiring
Normanjules
I'm trying to fit an aftermarket remote central locking to my 2013 Doblo Van. What pins do you connect to on the vehicle.
good evening, did you finally make it? I also have doblo 2011. I tried to find the cables that lock and unlock, I found only the unlock cable (purple/red Cable in black/blue connector position N.51).
but I can't find the lock cable.
any help would be welcome, Thanks
Hi Friend,
Did you suss out the wiring colours. I have a drawing of the N51 unit but the colours are all different.
Ta.
Maybe not much good but years ago a lad in the Fiat garage said that the way the Ducatos worked was that polarity of the signal was reversed to lock and unlock the door using the same cable.
Would seem a obvious way with a DC solenoid (y)
It would require both solenoid \ motor wires to change polarity could be done with a rotary relay 1 pulse changes relay VW used them on 6 volt headlamp dip relay many many moons ago
Think double pole change over switch X linked or in the body computer
has anyone found a way to install ??
this is the installation file sent by hawkalarm,
but i think it is for an older model
mine is doblo 2011 (263)
Hi did anybody work out which colour cables to connect to as I have a 2015 doblo trying to connect remote central locking to it
Hi, did anyone work it out? Or even find out what type of locking mechanism is used? (Negative,positive, positive and negative or baro-lock)
It works via 2 microswitches....1 is engaged when the door is opened/closed) the other when pushed in, locks the central locking- released unlocks.
purple/red is lock and unlock front doors only.
Purple/yellow is lock/unlock for the back doors.
The p/r and p/y wires carry 0.24v when a ground is introduced it unlocks, to get it lock the ground has to be moved about (I used torx head on the door hinge.
This leads me to believe it works on resistance,which in turn sends a 12v + or - to the door motors..I think I have to fit a resistor on the unlock signal....but my limited knowledge is totally exhausted.any help please... thanks in advance
That might be helpful. There are lots of diagrams for the central locking on the x263 Doblo, mostly due to the number of versions (single / double sliding doors, rear tailgate / rear wing doors). Here's the double sliding door + the rear wind doors version (as it's the most complex I assume).
  • x263 Doblo - eLearn - Electrical equipment - E3040 CENTRAL LOCKING.pdf
Thank you. Hopefully this info will help me sort it...I'll keep you updated.
