Technical  doblo clutch
wwwdodge
Manchester
hi i am having problems with the clutch slave cylinder on the gearbox keeps losing pedal travel after a few weeks of bleeding it. been told you can fit the one from a late punto as this has a proper bleed niple. has anyone had the same problem cheers duncan!!!!!:confused:
If air is getting into the system, and there's no leaks from the slave cylinder, then it points to a fault elsewhere, probably the master cylinder.
Why change a working part for the sake of it? By the way, Mk 2 Punto's don't have a "proper" bleed nipple either.;)
(y)
