Technical doblo brakes
bob H
hi all, hope someone can help...have a 2003 1.9 jtd with brake failure, the fault is with the load compensating valve for the rear brakes....have tried everywhere i can think of to try and get replacement, with no luck. new or secondhand. was wondering if this valve was used on other makes/models ? or if anyone has one please let me know
The part number varies a bit depending on model. Make sure you get one for diesel and you should be ok.
You could use eper in forum , input your vin and look up fiat part number then Google the fiat part number.
thanks for that info, at least i have the part number now....might make it easier to find one in the UK
