mickleplum
- Joined
- Dec 10, 2010
- Messages
- 6
- Points
- 1
OK fellow doblo owners - my 235,000 mile doblo cargo starts and then cuts out straight away. All lights on the dash go off as if no power. The bus will start up straight away but die again as soon as it starts. Doesn't do this all the time I might add.
Odd times when I put the key in and turn to the 1st ignition position some of the dash lights flash and the lights on the odometer flicker until I turn the ignition off and on again.
Today it had one of these do's but then cut out as I started to drive, the seatbelt light was also sticking on. Its had the crank sensor replaced so its not the usual fault of getting warm and cutting out etc (my sensor had managed to do 233,000 afore needing a change).
Am just wondering if there is some sort of key sensor in the column that may be faulty or whether it could be a dicky earth strap etc...
Would welcome any thoughts ...
Cheers Mick
Cheers Mick
