Recently my doblo van has started haveing problems starting, the local garage reconed it was the battery and replaced it which worked for a day or two then it was back to normal
when you go to start it, it will normally turn over at the normal speed but not fire although on occasions the engine will start but not pick up off of tickover and eventually die as though it's being choked.
Added to this the cooling fan has started comeing on even though the engine is stone cold and the glow plug light is staying on as well
does anyone have any idea's what this is likely to be?
thnx
thnx
