I have just installed disk brakes on the front and was hoping someone else that has installed them can tell me how they perform as I find them sluggish and not great braking ability. I have bleed the system, any advise would be appreciated.
No more handbrake turns as I used to do when I was 18 nearly 60 years ago, when I first bought a 500 in 1966 then another in 69. Best cars for fun after going through 78 cars (including a Bristol, Aston & Porsche’s since then. That’s why I bought this one last year as a last fun project
Hi Mike, The braking effect of disc brakes on a light car such as the 500 will depend on several factors. Most if not all disc brake mods originate from heavier, if not larger, cars and they may be vacuum assisted in some way. If you drive a modern car the effort your thigh muscle has to impart to brake is far less, so you mentally and physically don't push hard enough to get the same effect. The disc size and type is important as a plain disc is not as efficient as one that is vented or cross drilled (but they are for higher performance applications) and the pad material may not perform until some heat is introduced into them (please note that pad material does vary widely depending on the required use) You will probably find (if your pads are new) that the brakes WILL require bedding in before they perform well. The average bedding in process involves slowing the vehicle from 30mph/50kph to zero multiple times over some 100-200 miles depending on application, but, you must be careful not over do it and allow high levels of heat to dissipate before repeating the process. Most pads have a coating on the material surface that must be worn off and the bedding in process assists in doing this. I have just replaced my original pads (Galfer 139 FF) that are Spanish in origin they were very dirty in use and I'm hoping that a change to Ferodo FDB29 will help with this, but I've yet to start the bedding in process. All in all be prepared to strain your right thigh muscle to get decent braking
Ian.
Lots of good and relevant answers to the thread already, and it seems like you've found the problem (which is great) but I thought I'd share my experience having converted to front disc brakes a few years ago.
It's already been said that it'll take a little while to bed the pads and disc but, having said that, I noticed an immediate, huge improvement on the standard drums that the disc brakes replaced.
Before the conversion if I'd been driving the 500 for a while and jumped back into a modern car I sometimes used to almost put my chest into the steering wheel from braking too hard! That doesn't happen now and, although not as sharp as a modern car still, the disc brake conversion was instantly much, much better.
Once you fix the leak I'm sure you'll be pleased.
