Poperon Joined May 26, 2011 Messages 232 Points 161 Nov 16, 2020 #1 Hi, Discovered a few drops of oil on the bottom of the sump. Traced it to the joint between the dipstick pipe and the sump/block. There's a rubber grommet/seal held in place by a bolt/tab welded to the pipe (5). Anyone had this one? Cheers Ron Attachments Dipstick pipe.PNG 32.8 KB · Views: 109
2668GRIFFIN ''LUIGI'' Parked in the garage Joined May 12, 2012 Messages 2,325 Points 973 Location WISBECH,CAMBS Nov 16, 2020 #2 You have pretty much solved the issue yourself Remove tube replace seal...... refit done Luigi
