andyrousecar
- Joined
- Jul 14, 2015
- Messages
- 43
- Points
- 66
With my limited mechanical knowledge I feel I have definitely got to the bottom of the dip stick issue following a good thrash over Barbondale the other evening with no oil leak whatsoever.
The O-ring is not expected to have any mechanical strength at all, it's just a seal and only acts as one if the dip stick is held secure in the crank case by the V form of the dip stick design. I have found that the tension created by the V needs adjusting every time the dip stick has been taken out by slightly exaggerating the V with pliers.
The additional problem I was suffering from was that the dip stick is a seperate part to the collar that has the O-ring on it and the dip stick was vibrating enough that it was traveling through the collar so the V profile was no longer in the crankcase hole therefore the O-ring could no longer provide enough friction to keep the assembly together.......got it?
I fitted a simple retainer on the dip stick part against the O-ring collar (see picture) this stops the dip stick shaft being able to pass through the O-ring collar, no more oil leaks.
